gas intake problem? help!
i have a 1979 tomos bullet it wasnt getting gas then i ajusted the bango to give it gas then it ran. then i noteced the gas switch was off? so i turned it on and it staled out so i took off the gas line to see if t was letting gas out and it was. so it runes for a little while with the gas switch off then whil its running with the gas switch off and when i turn the gas on it stalles..... is it getting to much gas? what do i have to do to fix this it sucks:(
Re: gas intake problem? help!
Ron Brown /
Benny,
You have 20 posts on the forum in the last 90 days.
Most of the threads seem to be along the lines of "this is happening, someone tell me why so I don't have to think or read or do anything myself."
Obviously you have determined that having the gas turned on kills the engine so it has to be some kind of a flooding problem. Unless the choke is stuck on you know you are going to have to bite the bullet and pull the carb.
Just do it.
Ron
what the fuck
im new at this shit
Re: what the fuck
Ron Brown /
Benny,
No you're not. You just don't want to do things yourself. You want someone else to tell you everything. Lets face it, if you only read the threads on the forum that your posts appeared in, you could diagnose this one.
Ron
Re: what the fuck
ya know maybe i couldnt do it without the threads but i tryed! i fucking tryed. isnt moped army for advice and help! ya know fuck you i took every thing apart and i genuenly didnt know what to do and its fucken ok to ask for help and i dont need advice from snooty know it alls like you im glad you are better and smarter fuck off.
Re: what the fuck
Ron Brown /
Benny,
Thank you very much. Nicest thing anyone ever said about me.
You want to explain where in here you say you took everything apart? Btw, while you had everything apart, did you happen to notice if the choke was stuck on or the float was sunk or stuck?
Ron
Re: what the fuck
no nothing was stuck. i fixed it though...listen i feel really bad about all this i know im an ass im really sorry im just a hopeless fuck.
take care.
re:
well, if you fuel valve is broken, so even at off it give gas, and you adjusted the float to let in the gas faster, when you put the gas to on, it lets gas faster. this would probably flood your carb. readjust the float back to the origional position
re:
