cdi for sachs 504
mike thompson /
Is there a good cdi for sachs 504, one with good lights? Is it correct to assume that a cdi for a 505 does not fit a 504?
Re: cdi for sachs 504
505 has different stator size and flywheel taper. You could maybe swap in a d crank to use standard puch flywheel taper and use a minarelli v1 stator. Best bet if youre going for cdi is to get the black Peitcard cdi and a 2041 box.
