Re: Swapping wheels Tomos Silver Bullet
Saabsonettguy . /
The older tomos swingarms have a larger diameter piece on the end of the peg that catches the brake plate. The newer aluminum brake plate just has a slot. If the peg is long enough you might get away with just grinding that larger diameter piece down. Of course you could always just swap to a newer swingarm, since they're cheap.
