Can this pedster go any FASTER ????
"I have a 1995 Honda Elite SR 50, that is all stock and original. I would like to know what can I do to make this go a little faster? Is it possible to get up to 50 MPH? Would it involve some major modifications or some simple switch n' swaps? Thanks for any advice"
Re: Can this pedster go any FASTER ????
sean eddie /
": I have a 1995 Honda Elite SR 50, that is all stock and original. I would like to know what can I do to make this go a little faster? Is it possible to get up to 50 MPH? Would it involve some major modifications or some simple switch n' swaps? Thanks for any advice<p> yeah try putting boring it out and put new piston <br> and rings and little end bearings because i did this to my <br>honda melody and it went off the clock about(43 m.p.h.)"
SA 50
Do you know where to get a manual for these Elite things? I'm having a little trouble with mine and don't want to wait for the repair shopr to get around to it. <br>
if you want to make that thing get up to 60mph then take the govenor out.
"To go faster take the Govenor(RESTRICTER) out. this will probably make it 5-10 m.p.h. faster. Also, use high octane gas and good oil( i use Honda GN2-it is great!) Also, you can clean the air filter. That will also help a lot. It is right above the g"
