Re: vapor blasting and painting
Pushrod Fifty /
Masked with aluminum tape and then bead blasted and Rustoleum satin clear coat makes the alum stand out and has held up the best for me. Paint usually discolors from gas, oil and heat. Wet sanding until uniform and then #0000 steel wool will also clear coat well.
