Re: QT50 - MJ50 question
Jack Rutherford /
Lani at coppergasket63 will make them almost any size for you and may give you a better deal if you buy direct from him instead of through ebay. He's made me anywhere from 0.5mm to 3mm base gaskets. I think there's a limit on copper thickness but he can do thicker ones in aluminum.
I sent him an nc50 base gasket and he now makes them for nc50 which also means nu50, pa50 and nx50 are covered.
yeah pwonly is so outrageously overpriced on that rev plate and other things. I couldn't find it but they also charge big dollar for cylinder milling. I've got a belt sander now with a wide enough belt that I think I can do it myself and finish it off by hand with a piece of glass. (edited)
