Re: How fast is your moped and how did you get there?
Chöschi21 C.K. /
Normaly only going for Climbing Hills well and Cruising, so not to fast most of the time, my Maxi hit 39, maybe it was 40 with 13:45 Gearing before Spinning a Bearing, 65cc Airsal with a 15mm Bing opened up Filter and a Modified 22mm Exhaust. My Supermaxi got 17-18mph Srock, gets up to 22mph on a good day with the Cat removed and slightly upjetted, but she seems to be quite tired and has low compression, Worn Cluch, eiter Pistonslap or bad Pistonring and rhe Bearings in the Rear wheel are making noise. I use her as a run around because she is sooooo reliable, was at the Ace Cafe Lucerne Meet on Easter Monday, did actually overtake 3 Supermaxi son my way home.
My Hercules should run about 30-35 with the Windowed Piston, Decked Cylinder, "Sport" Airfilter and 28mm Exhaust, but it's still a long way to get it streetable.
  How fast is your moped and how did you get there?Topic by: Mark Miller Mark Miller 05/03/19 07:58PM
  Re: How fast is your moped and how did you get there?Re: Jack Rutherford Jack Rutherford 05/03/19 11:16PM
  Re: How fast is your moped and how did you get there?Re: cal mcclung cal mcclung 03/06/22 06:57PM
  Re: How fast is your moped and how did you get there?Re: P D P D 03/07/22 08:54AM
  Re: How fast is your moped and how did you get there?Re: Thomas TPRF Thomas TPRF 05/03/19 11:41PM
  Re: How fast is your moped and how did you get there?Re: Probably Fred Probably Fred 05/04/19 12:00AM
  Re: How fast is your moped and how did you get there?Re: Joe Schuitema Joe Schuitema 05/04/19 12:33AM
  Re: How fast is your moped and how did you get there?Re: Full Tuck Full Tuck 05/04/19 11:26AM
  Re: How fast is your moped and how did you get there?Re: Jeff Parr Jeff Parr 05/04/19 04:53PM
  Re: How fast is your moped and how did you get there?Re: Adam Smith Adam Smith 05/04/19 05:25PM
  Re: How fast is your moped and how did you get there?Re: Chöschi21 C.K. Chöschi21 C.K. 05/04/19 10:33PM
  Re: How fast is your moped and how did you get there?Re: Don Ohio Don Ohio 05/04/19 11:46PM
  Re: How fast is your moped and how did you get there?Re: Mark Miller Mark Miller 05/05/19 01:04PM
  Re: How fast is your moped and how did you get there?Re: Chöschi21 C.K. Chöschi21 C.K. 05/05/19 04:36PM
  Re: How fast is your moped and how did you get there?Re: Mark Miller Mark Miller 05/05/19 06:21PM
  Re: How fast is your moped and how did you get there?Re: Born to be WillD Born to be WillD 05/06/19 11:30AM
  Re: How fast is your moped and how did you get there?Re: Emil Kniemel Emil Kniemel 05/06/19 11:50AM
  Re: How fast is your moped and how did you get there?Re: Daniel '' Daniel '' 05/06/19 04:53PM
  Re: How fast is your moped and how did you get there?Re: Probably Fred Probably Fred 05/06/19 05:10PM
  Re: How fast is your moped and how did you get there?Re: Daniel '' Daniel '' 05/06/19 05:52PM
  Re: How fast is your moped and how did you get there?Re: Thomas TPRF Thomas TPRF 05/06/19 09:01PM
  Re: How fast is your moped and how did you get there?Re: Thomas Peffer Thomas Peffer 03/06/22 03:06PM
  Re: How fast is your moped and how did you get there?Re: punkrock randy punkrock randy 03/07/22 10:12AM
  Re: How fast is your moped and how did you get there?Re: P D P D 03/07/22 12:28PM
  Re: How fast is your moped and how did you get there?Re: Justin Krall Justin Krall 03/09/22 02:00PM
  Re: How fast is your moped and how did you get there?Re: b to the eff b to the eff 03/09/22 02:09PM
