Re: How fast is your moped and how did you get there?
Adam Smith /
Puch e50. Athena ajh 70cc. raised my cylinder 2.5mm decked the cylinder to 1mm squish exhaust timing around 185*. Dmp race crank.
Hi compression head.
8 petal reed block
Electronic ignition
Homoet p6 PSR Pipe
Mikuni TM24 leaner needle 4dh7 main jet 165 idle 10
17x41 hit 58mph.
Need some taller gears or a fancy cdi to push the mph up
  How fast is your moped and how did you get there?Topic by: Mark Miller Mark Miller 05/03/19 07:58PM
  Re: How fast is your moped and how did you get there?Re: Jack Rutherford Jack Rutherford 05/03/19 11:16PM
  Re: How fast is your moped and how did you get there?Re: cal mcclung cal mcclung 03/06/22 06:57PM
  Re: How fast is your moped and how did you get there?Re: P D P D 03/07/22 08:54AM
  Re: How fast is your moped and how did you get there?Re: Thomas TPRF Thomas TPRF 05/03/19 11:41PM
  Re: How fast is your moped and how did you get there?Re: Probably Fred Probably Fred 05/04/19 12:00AM
  Re: How fast is your moped and how did you get there?Re: Joe Schuitema Joe Schuitema 05/04/19 12:33AM
  Re: How fast is your moped and how did you get there?Re: Full Tuck Full Tuck 05/04/19 11:26AM
  Re: How fast is your moped and how did you get there?Re: Jeff Parr Jeff Parr 05/04/19 04:53PM
  Re: How fast is your moped and how did you get there?Re: Adam Smith Adam Smith 05/04/19 05:25PM
  Re: How fast is your moped and how did you get there?Re: Chöschi21 C.K. Chöschi21 C.K. 05/04/19 10:33PM
  Re: How fast is your moped and how did you get there?Re: Don Ohio Don Ohio 05/04/19 11:46PM
  Re: How fast is your moped and how did you get there?Re: Mark Miller Mark Miller 05/05/19 01:04PM
  Re: How fast is your moped and how did you get there?Re: Chöschi21 C.K. Chöschi21 C.K. 05/05/19 04:36PM
  Re: How fast is your moped and how did you get there?Re: Mark Miller Mark Miller 05/05/19 06:21PM
  Re: How fast is your moped and how did you get there?Re: Born to be WillD Born to be WillD 05/06/19 11:30AM
  Re: How fast is your moped and how did you get there?Re: Emil Kniemel Emil Kniemel 05/06/19 11:50AM
  Re: How fast is your moped and how did you get there?Re: Daniel '' Daniel '' 05/06/19 04:53PM
  Re: How fast is your moped and how did you get there?Re: Probably Fred Probably Fred 05/06/19 05:10PM
  Re: How fast is your moped and how did you get there?Re: Daniel '' Daniel '' 05/06/19 05:52PM
  Re: How fast is your moped and how did you get there?Re: Thomas TPRF Thomas TPRF 05/06/19 09:01PM
  Re: How fast is your moped and how did you get there?Re: Thomas Peffer Thomas Peffer 03/06/22 03:06PM
  Re: How fast is your moped and how did you get there?Re: punkrock randy punkrock randy 03/07/22 10:12AM
  Re: How fast is your moped and how did you get there?Re: P D P D 03/07/22 12:28PM
  Re: How fast is your moped and how did you get there?Re: Justin Krall Justin Krall 03/09/22 02:00PM
  Re: How fast is your moped and how did you get there?Re: b to the eff b to the eff 03/09/22 02:09PM
