Has anyone fabricated this roller clutch installer?It’s for a Tomos A3.
You dont need that. But treats does sell it if you fell you do.
Check check your socket set I bet one of them will fit just right to pop it out once you take the brass peace out the brass piece comes out the gear side by tapping it out through the shoe side and then once that's out you flip it and you can pop the other one out with a hammer you're going to need a new brass piece cuz it usually gets malformed pulling it out also the roller bearing if I'm not mistaken you got to check the signature side goes towards the engine but double check in the manual
Use a rubber mallet or a copper hammer
SlewFoot, the printed side does go toward the engine, maybe a 10 mm?
I think I actually used an extension and the section that actually attaches to the ratchet is what caught it and pulled it out it's been awhile
