Re: New Tomos Tomorrow.
♣Slew Foot♣ /
When before you buy it taken for a ride and then go down a hill and coasts and if the chain pops off it's the internal roller bearing gear in the clutch Bell it shot if that's bad double check the main counter shaft gear cluster it will most likely be missing the question marks spring and when you replace it you'll notice it doesn't function right then you'd have to take it apart and fix the internal kick starter cage the nut that goes on that countershaft though is spect to 52 Newtons which is outrageous it's sort of like a hundred fifty foot pounds
