Hobbit Advice
Picked this PA5OI over the winter. Ran ok. Put on some new tires, added DR70 kit, Keihin PC20 I had laying around.
After long WOT I GET a bad lean bog and it dies. Current is 95MJ and 38SJ.
Any advice on jets?
Re: Hobbit Advice
Beach Club Nick /
Probably a dumb question but you aren't running the stock pa50i reed/reedblock are you?
Re: Hobbit Advice
Bad fuel flow, bad tank venting.
Re: Hobbit Advice
Happy Pancake /
Sorry. PA50II reed block and intake. I was also thinking bad fuel flow w/ the elevated carb. Does 95/38 sound about right? I can hook up my AFR meter but don't want to gunk it up.
Re: Hobbit Advice
Happy Pancake /
Plug looks good
Re: Hobbit Advice
If the bike runs well at the beginning of a wot run and isn't dying due to extreme heat or plug fouling then it's not your jetting. The elevated carb means nothing if the fuel level is above the carb. Draining the float bowl due to clogged petcocks, inlet fittings, float needle seats etc will. Pulling a vacuum in the fuel tank because the cap isn't letting air in is more common than you'd think also.
Re: Hobbit Advice
Happy Pancake /
Thanks. 325F at WOT. I'll pull the petcock. There's an air bubble in the in-line filter. Pulls real hard to 45mph then hits that wall.
Re: Hobbit Advice
Air bubbles won't block you like that, 325 is way too low. You may be way rich or your timing is off.
Re: Hobbit Advice
Happy Pancake /
Timing was spot on when I checked. Used piston stop. I’ll recheck. Thx
Re: Hobbit Advice
Happy Pancake /
Petcock flow was a drip. Ordered a new one. I’m used to 4T scoots w fuel pump. Will update later. Thanks
Re: Hobbit Advice
Happy Pancake /
New petcock fixed the flow problems.
Got the front mag on. I need to make a brake cable.
Unapproved Message (moderated by simon)
Re: Hobbit Advice
Jerome Anderson /
lovely one, i like it !
Re: Hobbit Advice
Happy Pancake /
Mags look good.
Any tricks to getting brakes adjusted to work better ?
Re: Hobbit Advice
Paul Boyer (OFMC) /
Nice!!!
