value of a Minarelli engine/trans assembly
Value of a Minarelli V1 engine. What do you suppose a low-mileage, (most likely) functional V1 engine/trans assembly (no carburetor) might be worth in US dollars? I am considering buying another one. The seller has no idea what it's worth and neither do I. I want a fair shake but I don't want to rob this guy either.
Thanks.
Re: value of a Minarelli engine/trans assembly
100 bucks. If it is real nice with all the electronics and fan cover of say up to 250
EH 📣FCC of the QCB /
> say up to 250
Yep. Good numbers.
Sounds good. This engine has low miles (400), the fan is perfect, the flywheel and electrics look brand-new. When I pulled off the fan, I was nearly blinded by the brilliant golden finish on the flywheel. I'd pay $250 for it, sure. Sounds about right thanks for chiming in.
Treatland sold a new in box V1 a couple months ago for $599
wow
I would give $100.00
Tri-ped Dave O.D.B. /
Standard V1 is pretty common. I would pay $150-175 for a nice one. No more
> more
^This! A regular, pedal type, well-used one maybe up to 125 shipped.
Don. Agreeing with the likes of me in public may increase your chance of being considered mentally imbalanced
Dirty30 Dillon /
It's interesting that some folks are willing to pay $250 for an engine, that no matter how nice probably needs seals and gaskets, but some guffaw at buying an entire bike for anything more than $400.
If you're ok with $250, go for it. But I am sure you could find one for $100-150 less and have it require the same work.
