Re: Treats puch-hobbit head hard to impossible start?
Born to be WillD /
> Marc Friedman Wrote:
> The red was a sharpie to test whether the head is flat. So with the two
> copper washers the motor starts initially and ran great but wont restart
> until it totally cooled. The heat fouling is probably happening still
> because the upper part of the threads aren't into the metal of the head
> so the plug I believe heats irregularly.
> Anyway my verdict is these heads with too much material removed exposing
> plug threads are basically unuseable. Don't buy them is the verdict.
Better test and very easy for flatness (assuming you're sanding) is just runall sanding in one direction (like up/down) then turn 90 and sand one or 2 passes (like side to side) and look to see where the original up/down scratches remain. you don't need anything extra like a marker. I do this everytime i'm sanding something smooth. When you go down to a finer grit it's a good check that you've removed all the deeper gouges from the prior grit, you just keep swapping 90 in between each size
  Treats puch-hobbit head hard to impossible start?Topic by: Marc Friedman Marc Friedman 04/25/19 01:40PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 01:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 01:48PM
  Re: Treats puch-hobbit head hard to impossible start?Re: pat splat pat splat 04/25/19 02:06PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 02:27PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 02:36PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 02:37PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Dirty30 Dillon Dirty30 Dillon 04/25/19 02:47PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 02:37PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 03:04PM
  Re: Treats puch-hobbit head hard to impossible start?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/25/19 04:06PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 05:54PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/25/19 07:08PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 11:23AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 11:25AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 11:58AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 12:13PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 12:25PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 12:29PM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/26/19 12:46PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Dirty30 Dillon Dirty30 Dillon 04/26/19 12:36PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/26/19 02:39PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Graham Motzing Graham Motzing 04/26/19 12:39PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Born to be WillD Born to be WillD 04/26/19 01:19PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 01:27PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 06:41PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 10:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Pushrod Fifty Pushrod Fifty 04/27/19 06:20AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 01:41PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Pushrod Fifty Pushrod Fifty 04/27/19 06:27AM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/27/19 10:03AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 11:14AM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/27/19 11:26AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/27/19 09:15PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Born to be WillD Born to be WillD 04/29/19 01:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 02:00PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 06:40PM
  Re: Treats puch-hobbit head hard to impossible start?Re: kevin Smellaflange kevin Smellaflange 04/27/19 06:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 07:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 10:18PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/27/19 10:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 11:17PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Emil Kniemel Emil Kniemel 04/29/19 12:52PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/29/19 01:21PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Emil Kniemel Emil Kniemel 04/29/19 07:18PM
