Re: Treats puch-hobbit head hard to impossible start?
Marc Friedman /
Perfect start. Perfect immediate restart Max temp at work 380 then on way back crept up to 406 into the wind. Im not sure if all my new and old 126 studs are up to this task. The two new ones are perfect to torque. The two reused ....I wish I had bought two sets of the Vespa 126 because for some reason one was m6-m7 I'll probably get two new ones. Im so hoping that this is a reasonable way to get a decent air-cooled mild build Hobbit. The jailing of dos cycles ie motzig new creation is the best solution of a non slotted head for a reasonable price. No need if one is doing a simple mild build to do mods here. Stock rebuilt case or just slap on a Dr etc to a decent bottom get ahold of a bunch of 126 mm m6 or m6/m7 studs so just the Dr kit and the head needs hole enlarging. I don't know if 126 m6 studs exist but use those with a head gasket for a 44 mm ,
If a pa 1 crank then u need the pull start
If pa 2 crank go for a one way bearing.
Slap on a pipe and rejet and your temps will dip.
But again this plug when sitting but still super hot won't start. Put in a plug that's been in the freezer immediate start. So I need to get a new box of plugs and toss all these others to make sure what im testing with.
  Treats puch-hobbit head hard to impossible start?Topic by: Marc Friedman Marc Friedman 04/25/19 01:40PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 01:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 01:48PM
  Re: Treats puch-hobbit head hard to impossible start?Re: pat splat pat splat 04/25/19 02:06PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 02:27PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 02:36PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 02:37PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Dirty30 Dillon Dirty30 Dillon 04/25/19 02:47PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 02:37PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 03:04PM
  Re: Treats puch-hobbit head hard to impossible start?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/25/19 04:06PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 05:54PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/25/19 07:08PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 11:23AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 11:25AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 11:58AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 12:13PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 12:25PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 12:29PM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/26/19 12:46PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Dirty30 Dillon Dirty30 Dillon 04/26/19 12:36PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/26/19 02:39PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Graham Motzing Graham Motzing 04/26/19 12:39PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Born to be WillD Born to be WillD 04/26/19 01:19PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 01:27PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 06:41PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 10:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Pushrod Fifty Pushrod Fifty 04/27/19 06:20AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 01:41PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Pushrod Fifty Pushrod Fifty 04/27/19 06:27AM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/27/19 10:03AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 11:14AM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/27/19 11:26AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/27/19 09:15PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Born to be WillD Born to be WillD 04/29/19 01:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 02:00PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 06:40PM
  Re: Treats puch-hobbit head hard to impossible start?Re: kevin Smellaflange kevin Smellaflange 04/27/19 06:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 07:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 10:18PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/27/19 10:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 11:17PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Emil Kniemel Emil Kniemel 04/29/19 12:52PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/29/19 01:21PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Emil Kniemel Emil Kniemel 04/29/19 07:18PM
