Re: Treats puch-hobbit head hard to impossible start?
Born to be WillD /
> Graham Motzing Wrote:
> are you sure that is a B6HS plug and not a B6ES? it looks super long in
> the pictures, like an ES. that is what everyone posting thinks is
> happening.
> you can just take the compression washers off a couple burned up plugs
> and stack a few of them- poor mans index washer. It works ok but it
> isn't ideal.
It's a lot closer to ideal at least, but ideal is not using washers, and getting a proper plug, is that just milled that deep to make the dome? maybe you do need washers, but it's not OK as-is... your entire purpose running that head is to improve the squish, squish velocity, mixing, gas/air proximity all actively efficiently compressed at the plug, I mean the advantages to a properly cut head are being significantly affected by a giant wall of plug sticking out into the head. (yes I know most of the effect is at the edge of the band but still).
Also high comp proper squish is by design tight tolerances and your plug could totally be hitting. I don't really understand what you're looking for with this post still, everyone's been in pretty much agreement from the beginning that your plug is extending too far. And second that if you're fouling a lot, which it sounds like has been the case also, you are either not sparking consistently, a really real possibility if your piston's nearly dining on your plug, or your plug's too cold, or both. I mean people run 7's on stock bikes - a hotter plug that fits your head is a consistent recommendation, please don't ignore it, get that squared away and report back!
  Treats puch-hobbit head hard to impossible start?Topic by: Marc Friedman Marc Friedman 04/25/19 01:40PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 01:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 01:48PM
  Re: Treats puch-hobbit head hard to impossible start?Re: pat splat pat splat 04/25/19 02:06PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 02:27PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 02:36PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/25/19 02:37PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Dirty30 Dillon Dirty30 Dillon 04/25/19 02:47PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 02:37PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 03:04PM
  Re: Treats puch-hobbit head hard to impossible start?Re: EH 📣FCC of the QCB EH 📣FCC of the QCB 04/25/19 04:06PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/25/19 05:54PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/25/19 07:08PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 11:23AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 11:25AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 11:58AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 12:13PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 12:25PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Josiah Radebaugh Josiah Radebaugh 04/26/19 12:29PM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/26/19 12:46PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Dirty30 Dillon Dirty30 Dillon 04/26/19 12:36PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/26/19 02:39PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Graham Motzing Graham Motzing 04/26/19 12:39PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Born to be WillD Born to be WillD 04/26/19 01:19PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 01:27PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 06:41PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/26/19 10:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Pushrod Fifty Pushrod Fifty 04/27/19 06:20AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 01:41PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Pushrod Fifty Pushrod Fifty 04/27/19 06:27AM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/27/19 10:03AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 11:14AM
  Re: Treats puch-hobbit head hard to impossible start?Re: P D P D 04/27/19 11:26AM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/27/19 09:15PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Born to be WillD Born to be WillD 04/29/19 01:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 02:00PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 06:40PM
  Re: Treats puch-hobbit head hard to impossible start?Re: kevin Smellaflange kevin Smellaflange 04/27/19 06:45PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 07:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 10:18PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Totally normal JBOT Totally normal JBOT 04/27/19 10:26PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/27/19 11:17PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Emil Kniemel Emil Kniemel 04/29/19 12:52PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Marc Friedman Marc Friedman 04/29/19 01:21PM
  Re: Treats puch-hobbit head hard to impossible start?Re: Emil Kniemel Emil Kniemel 04/29/19 07:18PM
