Another sprocket ratio question, this time for Minarelli V1
Some 40 years ago, I wanted more speed out of my Motron (surprise it's a Motron, surprise I wanted more speed, right?) that originally came with 9:44 sprockets. First I bought an 11 for the front, so 11:44 and the bike, with no other enhancements, went 30 mph. Of course, I wanted faster, so I got a 36 for the rear. 40 mph on level ground but 10 to 15 up tough hills, so 11:36 ratio.
I'm getting the engine rebuilt this month after roughly 20 years since the last time it was ridden, and I'm thinking of going back to the 11:44 ratio, but I will need a longer chain, of course.
Or do i?
If I switch the front sprocket to a 9, a 9:36 will have the SAME RATIO as the 11:44, but my mechanic is saying that I will have an rpm issue at 9:36 that I won't have at 11:44.
Thoughts?
Re: Another sprocket ratio question, this time for Minarelli V1
Trent Anderson /
This chart has green/black, yellow/black, and yellow/red. Which combinations are good, bad, or ugly?
>>>taykoff [s2m] /
Green: Good.
Yellow: OK for kits that can huff it....bad for stock.
Red: Bad. (Exceptions can be made for wizards rocking LC scooter kits)
Magic ratio number to shoot for is 3.4 typically for v1's...
Dirty30 Dillon /
> Trent Anderson Wrote:
> My mechanic is saying that I will have an rpm issue at
> Thoughts?
He is mistaken. If anything, the smaller sprockets and shorter chain give you less rotational mass.
🇮🇹💦 Of the Loin /
11x33 can be pulled by a polini 80 ask me how
Less rotational mass? The reduction of mass is so small it really doesn't matter. I could argue that more teeth and more chain will wear out slower.
on a stock set up with 11x36!? thats nutz, I run 10-36/32 on my kitted V1's, there is no way in hell I could handle that gear ratio with out all the mods on my motor
also your doing it wrong having someone else build your bikes, your doing it even more wrong second guessing his knowledge, when you yourself cant rebuild the motor.
but at least its Richard building them, and he knows what he's doing
Dirty30 Dillon /
> out slower.
You're talking about like 10 links just off the chain ... that's pretty substantial.
I would rather be turning smaller gears at the same ratio than larger gears at the same ratio.
Small gears wear faster than larger gears .
larger gears results in less change in angle of each individual link and less line-pull torque, running over a small gear will always wear out a chain faster than running over a larger gear.
buuuuut
its mopeds so who gives a fuck.
> buuuuut
Lest we forget . LOL
Trent Anderson /
Much better for me to learn by trial and error, with the wrong tools, ruin 12 motors, hope I rebuild at least one engine correctly, and spend all my time "wrenching" than have one of the few people on this site that actually know what they are doing rebuild my motors.
Got it.
No one said education is cheap . ;)
🇮🇹💦 Of the Loin /
Mopeds are low enough effort and also need some extra thought into reliability that you don't need a mechanic and should probably figure your favorite brand out yourself
Cars are another story
