Ok, I did some WIKI reading and web searches before this ,so bear with me . I got a A3 1990 bullet. I want to do clutch work on it. I guess good cork is hard to find, also I read the steel on the clutches is probably bad also I don't know why. So A3 clutches are hard to find, but A35 & 55 's are everywhere. So I read these two are pretty much the same. So I went to Myrons Moped and that that 35 and 55 "bottom ends" have wider gears & clutches,bigger roller clutches. Am I missing something cause the parts sites seem to tell me the clutch kits are only A 35 - A55? Would the wider parts not fit?
