Re: Dumb quick fix for sachs starter cables
♣Slew Foot♣ /
another good trick is to put a Bic pen spring on the decomp PIN to hold it up all the time it screws on there and it will stop it from pushing in. You can also use a brake line and cut it and drill it then you take solder and you fill it once you put a frayed wire through it you coat the inside of it with wax or even paper once the mold is made with The Frayed and then and it comes out after you pour the hot lead into it you can then cut off the copper I don't even think it would stick if you didn't even put anything in there just because of the nature of the metals
