Re: Are motorcycles safer then stock mopeds?
Don Ohio /
You need to work on your brakes. The rear should nearly lock-up and the front should just about put you over the handlebars. IF you're going to run 60 on a moped, you have no excuse not to mod it to disc brakes.
Maybe you weigh 300 lbs...…………...after all it is inertia and that is physics. Below,make sure you read the last SIX WORDS.
What we need to look at is:
If you have a 2,000 kg car (which is about 4400 lbs) that is driving at 10 m/s (or about 22 mph), you would have a kinetic energy of 100,000 Joules. If you doubled your speed to 20 m/s (which is about 45 mph), your kinetic energy would be 400,000 J. In this example, it is clearly apparent that higher speeds will result in higher energy crashes. By doubling your speed, you increase the energy in a collision by FOUR TIMES, which makes it significantly more dangerous.
  Are motorcycles safer then stock mopeds?Topic by: Simon Belmont Simon Belmont 04/18/19 10:02PM
  Re: Are motorcycles safer then stock mopeds?Re: Josiah Radebaugh Josiah Radebaugh 04/18/19 10:10PM
  Re: Are motorcycles safer then stock mopeds?Re: Stephen Keller Stephen Keller 04/18/19 10:14PM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/18/19 10:34PM
  Re: Are motorcycles safer then stock mopeds?Re: Dirty30 Dillon Dirty30 Dillon 04/18/19 10:59PM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/18/19 11:34PM
  Re: Are motorcycles safer then stock mopeds?Re: Jeremy cole Jeremy cole 04/18/19 11:09PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/18/19 11:36PM
  Re: Are motorcycles safer then stock mopeds?Re: Rob Rob Rob Rob 04/19/19 02:42AM
  Re: Are motorcycles safer then stock mopeds?Re: Rob Rob Rob Rob 04/19/19 03:09AM
  Re: Are motorcycles safer then stock mopeds?Re: Captain Janeway Captain Janeway 04/19/19 10:20AM
  Re: Are motorcycles safer then stock mopeds?Re: Dirty30 Dillon Dirty30 Dillon 04/19/19 11:01AM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/19/19 03:06PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/19/19 03:50PM
  Re: Are motorcycles safer then stock mopeds?Re: Dave & Bummerzz Dave & Bummerzz 04/19/19 11:09AM
  Re: Are motorcycles safer then stock mopeds?Re: Probably Fred Probably Fred 04/19/19 12:28PM
  Re: Are motorcycles safer then stock mopeds?Re: kevin Smellaflange kevin Smellaflange 04/19/19 12:08PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/19/19 12:37PM
  Re: Are motorcycles safer then stock mopeds?Re: Aaron Ward Aaron Ward 04/19/19 12:43PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/19/19 12:46PM
  Re: Are motorcycles safer then stock mopeds?Re: Aaron Ward Aaron Ward 04/19/19 01:00PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/19/19 01:42PM
  Re: Are motorcycles safer then stock mopeds?Re: Always Working Always Working 04/19/19 01:07PM
  Re: Are motorcycles safer then stock mopeds?Re: Stephen Keller Stephen Keller 04/19/19 06:46PM
  Re: Are motorcycles safer then stock mopeds?Re: Brad William Brad William 04/19/19 02:12PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/19/19 02:19PM
  Re: Are motorcycles safer then stock mopeds?Re: kevin Smellaflange kevin Smellaflange 04/19/19 02:20PM
  Re: Are motorcycles safer then stock mopeds?Re: Captain Janeway Captain Janeway 04/19/19 05:21PM
  Re: Are motorcycles safer then stock mopeds?Re: Max Ginsburg Max Ginsburg 04/19/19 06:24PM
  Re: Are motorcycles safer then stock mopeds?Re: P D P D 04/19/19 06:34PM
  Re: Are motorcycles safer then stock mopeds?Re: Jeff Parr Jeff Parr 04/19/19 06:51PM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/20/19 06:26AM
  Re: Are motorcycles safer then stock mopeds?Re: Douglas Binder Douglas Binder 04/20/19 09:51AM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/20/19 12:56PM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/20/19 11:12PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/20/19 11:35PM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/21/19 02:36AM
  Re: Are motorcycles safer then stock mopeds?Re: Stephen Keller Stephen Keller 04/21/19 03:28PM
  Re: Are motorcycles safer then stock mopeds?Re: Bas Autowas Bas Autowas 04/22/19 08:33AM
  Re: Are motorcycles safer then stock mopeds?Re: Dirty30 Dillon Dirty30 Dillon 04/22/19 10:37AM
  Re: Are motorcycles safer then stock mopeds?Re: Stephen Keller Stephen Keller 04/22/19 02:44PM
  Re: Are motorcycles safer then stock mopeds?Re: Born to be WillD Born to be WillD 04/22/19 11:46AM
  Re: Are motorcycles safer then stock mopeds?Re: Douglas Binder Douglas Binder 04/20/19 02:35PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/20/19 02:55PM
  Re: Are motorcycles safer then stock mopeds?Re: Douglas Binder Douglas Binder 04/20/19 03:47PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/20/19 04:16PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/20/19 05:10PM
  Re: Are motorcycles safer then stock mopeds?Re: Chöschi21 C.K. Chöschi21 C.K. 04/20/19 08:15PM
  Re: Are motorcycles safer then stock mopeds?Re: Douglas Binder Douglas Binder 04/20/19 05:28PM
  Re: Are motorcycles safer then stock mopeds?Re: Don Ohio Don Ohio 04/20/19 11:06PM
  Re: Are motorcycles safer then stock mopeds?Re: Born to be WillD Born to be WillD 04/20/19 09:42PM
  Re: Are motorcycles safer then stock mopeds?Re: Jesse Simonsen Jesse Simonsen 04/21/19 10:30AM
  Re: Are motorcycles safer then stock mopeds?Re: Born to be WillD Born to be WillD 04/21/19 10:57AM
  Re: Are motorcycles safer then stock mopeds?Re: ♣Slew Foot♣ ♣Slew Foot♣ 04/22/19 08:29AM
  Re: Are motorcycles safer then stock mopeds?Re: Bas Autowas Bas Autowas 04/21/19 10:37AM
  Re: Are motorcycles safer then stock mopeds?Re: kevin Smellaflange kevin Smellaflange 04/21/19 10:45AM
  Re: Are motorcycles safer then stock mopeds?Re: Pushrod Fifty Pushrod Fifty 04/21/19 04:11PM
