I have a Garelli Rally 86 and it has spark but I’m not getting it to start. The carburetor is clean. I try to start it with starting fluid it won’t start either. Any suggestions?
Thanks
> Thanks
New spark plug?
It needs a heavy blue spark. If the plug is wet with gas after kicking over and its fresh gas, then the issue could be that the pipe is clogged. Try taking the pipe off the cylinder and see it starts. (edited)
did you actually CLEAN the carb? or are you just saying it looks clean? it can look clean as a wistle and not meter fuel correctly.
