Rear sprocket
I found this 45 tooth sprocket vs the normal 40 tooth has anyone ever used one
Re: Rear sprocket
kevin Smellaflange /
what do they fit?
Re: Rear sprocket
Dirty30 Dillon /
45 Tooth is standard equipment on stock 2hp Puch E50's.
Re: Rear sprocket
Not that you are asking about ratios , but , in the big bike world , we usually figure dropping one tooth in the front is very close to adding 4 teeth in the rear .
Maybe you're asking if there would be any chain clearance issues ?
Re: Rear sprocket
I have 2 speed puchs with 5 stars and they are 40
Re: Rear sprocket
Dirty30 Dillon /
Yep, Stock gearing fo ZA50 1.5/2HP is 40 rear.
Re: Rear sprocket
If I put the 45 and change the chain would it make that much of a difference
Re: Rear sprocket
Chöschi21 C.K. /
Never seen a Puch with anything different than 45 in the Rear.
Re: Rear sprocket
Jeremy Homser /
Harry take a look at this gearing calculator it should help.
http://toolbox.martysgarage.info
Re: Rear sprocket
> difference
Better take off and slower top end most of the time
Re: Rear sprocket
Dirty30 Dillon /
> difference
Acceleration would increase quite a bit, but your top speed would decrease. Typically, I go the other way with ZA's, especially with flipped second speed clutches
Re: Rear sprocket
Yea, your za50/polini should be running 20x35 gears or so.
Re: Rear sprocket
Probably Fred /
> Daniel '' Wrote:
> Yea, your za50/polini with derestricted estroil pipe should be running 20x35 gears or so.
I run 21x35 on polini kit 4 pedal reed cage and derestricted estroil pipe flipped second gear clutch on za50 and go 55-60 mph all day long and that’s with static points ignition and around 14° BTDC timing!
Re: Rear sprocket
Ken you don't quote someone then add words to their statement. It makes it not a quote anymore when you do that.
Re: Rear sprocket
Maybe you should read his post again .
Seems to me he's stating what he runs as a comparison .
Re: Rear sprocket
Its not that big of a deal, but he did add a words to my statement in the quotations from my original post.
Re: Rear sprocket
> teeth in the rear .
What?
Re: Rear sprocket
> Rocco Taco Wrote:
> we
> 4
> > teeth in the rear .
> What?
Dude the chain is going to count the teeth. 16x45 & 11x40 are the same.
https://docs.google.com/spreadsheets/d/1gSoOgAuJittzdIy3M0EVFE27OhlEbqacSnFbv7gT4TM/htmlview# (edited)
Re: Rear sprocket
> Rocco Taco Wrote:
> > Rocco Taco Wrote:
Actually, the 16/45 is closer to a 14/40 or so.
Re: Rear sprocket
Never thought I'd say this, but Don is right
Re: Rear sprocket
> Don Ohio Wrote:
> > Rocco Taco Wrote:
> > > Rocco Taco Wrote:
> same.
Yea I know if you look at the spreed sheet rpms I posted it says that.
Math
45/5=9
40/5=8
16/5=3.2
11/5=2.2
Does anyone know why this happens?
Re: Rear sprocket
> Math
> 45/5=9
> 40/5=8
> 16/5=3.2
> 11/5=2.2
It's simple math : Division .
And , the chain doesn't matter . It gets adjusted to the sprockets that are chosen .
I wasn't sure exactly what the OP was asking , so I offered ...
