Years ago my plug stripped on an MO2 engine. Auto-Zone had an oversize plug that fit perfectly on 8mm,I believe. Still you need to remove the aluminum bits inside the case so they don't tear up anything.
Subject | Written By | Posted |
Drain plug strippedTopic by: Josh Kiser | Josh Kiser | 04/04/19 08:42PM |
Re: Drain plug strippedRe: * * | * * | 04/05/19 05:01AM |
Re: Drain plug strippedRe: Chris Straub | Chris Straub | 04/05/19 05:07AM |
Re: Drain plug strippedRe: Graham Motzing | Graham Motzing | 04/05/19 09:18AM |
Re: Drain plug strippedRe: Full Tuck | Full Tuck | 04/05/19 11:28AM |
Re: Drain plug strippedRe: Brad William | Brad William | 04/05/19 01:07PM |
Re: Drain plug strippedRe: * * | * * | 04/05/19 01:38PM |
Re: Drain plug strippedRe: Don Ohio | Don Ohio | 04/05/19 01:49PM |
Re: Drain plug strippedRe: Jeff Parr | Jeff Parr | 04/05/19 02:09PM |
Re: Drain plug strippedRe: Adam Smith | Adam Smith | 04/05/19 04:01PM |
Re: Drain plug strippedRe: Josh Kiser | Josh Kiser | 04/05/19 05:35PM |
Re: Drain plug strippedRe: Don Ohio | Don Ohio | 04/05/19 05:48PM |
