Re: Puch pinto brake help
Dirty30 Dillon /
First off, your fork legs are rotated 180* wrong. The square welded on bracket with two holes is the fender support.
Secondly, that's a motobecane brake plate which will not function on the forks you have. I would check to make sure you even have a Puch front wheel. Otherwise, you will have problems matching the puch leleu brake plate to the hub.
