Re: An American Microcar/V1 Build
Dmitry K. /
I would be cautious about that scheme of yours.
That's a Peerless Gear model 100 differential. These can be had for as low as $170 plus ship from places like this. There are several variations of the same model and I'm sure none are plug and play in moped application. Axle halves are not interchangeable as I found out trying to source a longer RH axle half. Spline ends are different, etc. Some are built to withstand greater loads than others, built tougher. Luckily I was able to return all the stuff that didn't work.
Mine came is what is called Peerless Differential Kit and came with blank axle halve ends albeit sufficient length to work with offset motor, completely disassembled, included a giant tube of differential grease, gasket material, oil seals, all hardware, and was more money.
Here I tried ordering a longer axle half from a different model which wasn't compatible.
Here's another example of a one wheel drive on my 2yo daughter's trike. That's about the only suitable application of a one wheel drive because on a large vehicle such as the microcar a single force of the driving wheel is acting off-center to the center of mass of the microcar making it always turn as it accelerates. I'm sure Stu Pivar's chose his one wheel drive design because it was low end mechanically simple like that trike of mine and cheap.
  An American Microcar/V1 BuildTopic by: Dmitry K. Dmitry K. 04/01/19 09:30PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 04/01/19 10:03PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 04/01/19 10:32PM
  Re: An American Microcar/V1 BuildRe: JBOT Admin JBOT Admin 04/01/19 10:54PM
  Re: An American Microcar/V1 BuildRe: Born to be WillD Born to be WillD 04/03/19 03:49PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 04/01/19 11:23PM
  Re: An American Microcar/V1 BuildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 04/02/19 05:30AM
  Re: An American Microcar/V1 BuildRe: Max LGN Max LGN 04/02/19 06:28AM
  Re: An American Microcar/V1 BuildRe: Graham Motzing Graham Motzing 04/02/19 10:46AM
  Re: An American Microcar/V1 BuildRe: todd amundson todd amundson 04/02/19 11:33AM
  Re: An American Microcar/V1 BuildRe: Graham Motzing Graham Motzing 04/02/19 02:22PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 04/02/19 05:51PM
  Re: An American Microcar/V1 BuildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 04/02/19 06:10PM
  Re: An American Microcar/V1 BuildRe: Graham Motzing Graham Motzing 04/03/19 04:34PM
  Re: An American Microcar/V1 BuildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 04/04/19 05:33AM
  Re: An American Microcar/V1 BuildRe: Born to be WillD Born to be WillD 04/17/19 09:09AM
  Re: An American Microcar/V1 BuildRe: Dave & Bummerzz Dave & Bummerzz 04/04/19 09:15AM
  Re: An American Microcar/V1 BuildRe: >>>taykoff [s2m] >>>taykoff [s2m] 04/04/19 01:40PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 04/04/19 07:51PM
  Re: An American Microcar/V1 BuildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 04/04/19 04:36PM
  Re: An American Microcar/V1 BuildRe: P D P D 04/04/19 04:41PM
  Re: An American Microcar/V1 BuildRe: >>>taykoff [s2m] >>>taykoff [s2m] 04/04/19 11:55PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 04/16/19 08:03PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 06/26/19 12:14AM
  Re: An American Microcar/V1 BuildRe: Graham Motzing Graham Motzing 06/27/19 02:05PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 06/27/19 11:17PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 06/26/19 12:19AM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 06/26/19 12:25AM
  Re: An American Microcar/V1 BuildRe: kevy Piepkorn kevy Piepkorn 06/27/19 01:20PM
  Re: An American Microcar/V1 BuildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 06/29/19 06:05PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 09/09/19 02:42PM
  Re: An American Microcar/V1 BuildRe: Stephen Keller Stephen Keller 09/09/19 03:21PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 09/09/19 02:44PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 09/09/19 02:50PM
  Re: An American Microcar/V1 BuildRe: >>>taykoff [s2m] >>>taykoff [s2m] 09/09/19 03:15PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 09/09/19 07:00PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 08/24/20 11:33PM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 08/24/20 11:52PM
  Re: An American Microcar/V1 BuildRe: Stephen Keller Stephen Keller 08/25/20 01:00AM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 08/25/20 12:17AM
  Re: An American Microcar/V1 BuildRe: Dmitry K. Dmitry K. 08/25/20 12:40AM
