Re: Adjustable chain tensioner for round tube
Thomas TPRF /
I’ve seen on motorcycles where folks will use a skateboard wheel mounted on a car belt tensioner. Gives ya a nice clean looking spring loaded arm. You could even polish the aluminum for some bling.
Most of the belt tensioners I’ve dealt with have a single bolt and a locating pin, all you’d have to do fab wise is weld an appropriate tab to your swing arm.
Might be overkill for the job though.
