new bearings fitted, but still huge amount of play when holding wheel, to check for play. is it a fault of the spacers, or the poor fit in the bearings, when spindle put through the bearings, i would have thought the spindle should be a tap through fit. nowhere near that, would not pass any m.o.t test as it is. ONE can see the wheel moving on the outside of the wheel on the spindle. i think the bearings are far to small for the job they have to do, and not designed to fit on the extreme outer edge of the hub for more security,
