Snowflake rear wheel shake
I destroyed a snowflake rim on a pot hole bad. So I grabbed one off the shelf and went to install it. But I noticed it had a small shake in it. I decided to check the bearing and noticed the cone was loose a little so I decided to tighten it up. Well I can't tighten the cone anymore or the bearings binds (even after a rebuild). I checked another rear snowflakes including the one I removed and they all had the same lil wobble. the axles are bent (11mm) so they had to leave the cone a lil loose for the high spot? Is this common? non of my spoke rims do this. (edited)
