TOMOS A55/52 STATOR TORQUE
I have looked on wiki, and it does tell you the flywheel torque (22ft. lbs.), but what is the torque spec for the stator coil bolts??? Thanks for the help and information guys!
Re: TOMOS A55/52 STATOR TORQUE
tight enough to not fall out, not too tight to break the bolts
they are m4 so not much, like maybe 2-3 inch lbs? i use loctite on tem and don't really torque them just snug with a screwdriver/allen wrench.
most torque wrenches cant read that low.
Quentin Moon /
Thanks for the tips guys I just wanted a second opinion! :-)
