Mo bat score
Guy on the other side of towns been trying to get me to buy this from him for a year now. We finally came down to a reasonable price. I’m not really into Batavus, but It was love at first ride. I adore this thing. It feels like a toy. The first time I ever saw one of these I thought it was some custom paint and decals someone had done to an hs50.. I got it running at the guys house with a carb cleaning, and poked some wire through the jet. It fired right up. He hadn’t seen it run in since the 90s. I’m rollin down his driveway ready to ride it home and he’s wait!” Don’t forget these” hands me a few books.. owners manual, Batavus maintenance book from eBay and the clymer publications Batavus moped book. (I’ve seen these on eBay before. They are great books full of useful info) In it was the registration from the last three times it was on the road, and the title! other than new tires, I’m going to keep it all original and bone stock. The only difference I can tell between the hs50 and the mo bat are the forks.. maybe something else?
Re: Mo bat score
You done good!
Re: Mo bat score
Josiah Radebaugh /
Things Minty! Hows the forks? (edited)
Re: Mo bat score
Alexandro Ramirez-Nagy /
Proud, mo-bats are pretty darn lit.
Re: Mo bat score
Love that Top-Tank! Let her rip!
Re: Mo bat score
Tri-ped Dave O.D.B. /
from the brochure
Re: Mo bat score
Thanks guys! The forks work great. The picture makes it look better.. it’s crusty up close haha. I am stoked about it though. I’ve got another Batavus that I’m going to use as a parts bike. The wheels, engine, exhaust ect. The speedometer says 74 miles so the parts are pretty fresh. Side note the exhaust on the parts bike has a larger header.. my gut is telling me itll give me some more speed? Not to mention it’s not nearly as gummed up.
Re: Mo bat score
The most annoying thing about the Laura 48 motor is the take off. The clutch grabs way too early and the motor cannot produce enough torque at such low rpm. Here is a neat trick to help that. The spring around the clutch that is filled with steel ball bearings unscrews open. Open it and replace every other steel ball with an aluminum one of the same size. This will lighten it and make it grab at a higher rpm, giving you much improved acceleration from stand still.
Re: Mo bat score
Noted!! Thanks for the tip. It’s definitely sluggish on the take off when it’s warmed up. The larger header from the parts bike seems to have added some top speed. I thing once everything is greased up again it’ll do a strong 30
Re: Mo bat score
Will any of the rear racks you find on other Batavus bolt on to this?
Re: Mo bat score
nice! i would probably have one if i found one. never seen one in person.
Re: Mo bat score
Best of luck finding any aluminum balls that exact size for the much preferred upgrade, hardware stores stock STEEL balls. Online only sadly, still be careful when ordering.
That 28mm header is the best swap and lucky you had one!!
For no reason should the mobat ever have been built with the 22mm one, as did mine I noticed.
The Front forks are a rare item for Batavus mopeds, I wanted someone with a Gran Prix to confirm that it also has the same ones but haven't heard from anyone yet???
Re: Mo bat score
I can confirm that the grand prix forks are not the same.
Re: Mo bat score
I know McMaster Carr carries ceramic balls.. I’ll have to weigh the steel balls out and see what’s up.
Re: Mo bat score
The rear portion of the frame (under seat) is pretty universal, ALTHOUGH I believe it was the later models 79+ (Regency/Starflite) that had the chrome rear monster rack which uses the rear shock mounting point and is NOT the same for VA/HS50/Mobat.
I added pics for the comparisons
78 Regency(black) 77 Bronco(yellow middle) 77 VA(same as Hs50+Mobat)
Re: Mo bat score
I think I got my last set of aluminum ball bearings from McMaster-Carr as well
Re: Mo bat score
Bruce Zapper /
Nice find! It took you a year? I would have bought that day one! Looking forward for the yard sales to begin!
Unapproved Message (moderated by simon)
Re: Mo bat score
Marc Belfort /
Good job !
Re: Mo bat score
He wanted 800 bucks for it at first.. it took a year for him to finally come down to 250. I actually ended up giving him 300 after he surprised me with the three books, title , and two new tubes still in the box. Really interesting older dude.. we actually shared some common interests.
Re: Mo bat score
wow, whatta great bat party
Re: Mo bat score
> interests.
Killer deal for a cool ass bike.
Re: Mo bat score
Yes to Chefs Mod of replacing every other ball. I did not think of aluminum but went to cutting small same diameter sections of that yellow/green fuel lime to replace every other ball. Worked great.
