Re: Rebuilding Shocks¿
Graham Motzing /
yeah i've taken a few shocks apart and put different springs in them.
you gotta compress the spring down and usually there is some kinda plastic collar covering up a locknut where the shock rod goes into the end cap. you compress the spring down in an arbor press or something, then you loosen that locknut, screw off the end cap. the whole thing comes apart and you can cut coils off your springs or mix'n'match them or whatever you wanna do.
