Re: diving deeper into the sha
P D /
> Ben Whittle Wrote:
> There isn’t an idle jet on Sha carbs. Idle is only set with the screw or
> notching the slide. That hole below the venturi is also drilled into the
> emulsion tube. If you take the tube out, make sure it’s realigned or
> else you won’t have an idle.
> Graham did a good blog post many years ago you should read on
> outofcontrolmopeds
True that^ , from what I gather .
So , I should have said idle 'circuit' instead of 'jet' .
