Re: diving deeper into the sha
Ben Whittle /
There isn’t an idle jet on Sha carbs. Idle is only set with the screw or notching the slide. That hole below the venturi is also drilled into the emulsion tube. If you take the tube out, make sure it’s realigned or else you won’t have an idle.
Graham did a good blog post many years ago you should read on outofcontrolmopeds
