I'm just confused how to set up the clutch plate if the decomp is covered. The cable running from my clutch on my handlebars, where would the other end go?
Born to be WillD Wrote:
> the details are in that wiki, you wanna actually remove the decomp valve
> from the cylinder, replace it with a bolt. You can take the little clip
> spring part off the original decomp and leave it in-line on the starter
> cable if you wanna halfass it and not have to recable the starter
> clutch, it's understandable, it's a sortof unique cable and replacing it
> can be tricky
