pipes
william rexford /
Had a tecno ran good . changed to a MLM people pipe runs good but when let off the gas a little it go's flat like no power give it a little gas jump back WTH.
Re: pipes
Make sure to do a plug chop after that pipe change. May be really lean now.
Re: pipes
Sounds like it's doing exactly what it's suppose to do .
Makes power when on the throttle and not when you let off .
Re: pipes
I don't think that's what he means,PD. He's losing pull when he lets off. Like almost no pull and moped just slows down. That's how I read it. Need better description.
Re: pipes
Any motor slows down when you let off the gas . That's the nature of the beast .
Re: pipes
Actually,if you're 4-stroking, they speed up when you let off. (:^)
Maybe he'll explain what he meant.
Re: pipes
If it's the way Don describes then I would wager that the needle is lean (if it has one) and the mid throttle range needs more fuel than the last pipe did.
Re: pipes
> pipe did.
This^^^^
