prolly not the pipe
Fred /
The first thing I would do is pull off the silencer (little muffler on the end) and run it... any difference?
Then I would buy a brand new spark plug and run that... any difference?
If neither of those work >>
Then I would pull off the gas line to the carb and make sure it flows good.... good flow?
Then I would take the carb off and clean it correctly....and run it...... still bad?
Then I would clean and set the ignition points correctly...(if you have points.. I think it does)
You did not harm anything by welding a crack in the pipe...(unless you stepped on the pipe and crushed it to half its diameter... and I'm sure you didn't)
About 95% of all moped problems are
clogged carb
dirty, misadjusted points
old spark plug
The odds of your problem being the pipe is about 1000 to 1 ...(unless the silencer is clogged)
  BITURBO CHAMBER. NEED HELP!!Topic by: Tim Salter Tim Salter 11/07/00 02:23PM
  prolly not the pipeRe: Fred Fred 11/07/00 04:02PM
  RE: prolly not the pipeRe: Tim Salter Tim Salter 11/07/00 08:01PM
  RE: BITURBO CHAMBER. NEED HELP!!Re: Ivo Ivo 11/09/00 10:17PM
  RE: BITURBO CHAMBER. NEED HELP!!Re: Tim Salter Tim Salter 11/11/00 01:13AM
  It's not the pipe!Re: Fred Fred 11/11/00 02:11PM
  RE: It's not the pipe!Re: mike mike 11/11/00 08:13PM
  RE: It's not the pipe!Re: mike mike 11/11/00 08:14PM
  RE: It's not the pipe!Re: Tim Salter Tim Salter 11/12/00 12:12PM
  RE: It's not the pipe!Re: mike mike 11/12/00 06:58PM
  RE: BITURBO CHAMBER. NEED HELP!!Re: Brian Vigna Brian Vigna 01/13/01 04:55PM
