BITURBO CHAMBER. NEED HELP!!
Tim Salter /
i have a bore kit on my tomos which up until recently has been running fine. The bike started to pop and sputter at high speed, which has happened before, do to the biturbo leaking. I found that there was a large break in the meatl right where the center bracket holds it onto the moped. I was able to seal up the hole by welding it. However, this did nto full fix the problem. I am almost posotive that it is not leaking any where, because i just put a new gasket in, and sealled the hole, and yet it still sputers very little at high speeds. Is it possible that i somehow changed the internal dimensions or something that would be causing this? i would appreciate some help on the subject, because i may end up buying a new pipe, if i cant get it to stop sputtering.
  BITURBO CHAMBER. NEED HELP!!Topic by: Tim Salter Tim Salter 11/07/00 02:23PM
  prolly not the pipeRe: Fred Fred 11/07/00 04:02PM
  RE: prolly not the pipeRe: Tim Salter Tim Salter 11/07/00 08:01PM
  RE: BITURBO CHAMBER. NEED HELP!!Re: Ivo Ivo 11/09/00 10:17PM
  RE: BITURBO CHAMBER. NEED HELP!!Re: Tim Salter Tim Salter 11/11/00 01:13AM
  It's not the pipe!Re: Fred Fred 11/11/00 02:11PM
  RE: It's not the pipe!Re: mike mike 11/11/00 08:13PM
  RE: It's not the pipe!Re: mike mike 11/11/00 08:14PM
  RE: It's not the pipe!Re: Tim Salter Tim Salter 11/12/00 12:12PM
  RE: It's not the pipe!Re: mike mike 11/12/00 06:58PM
  RE: BITURBO CHAMBER. NEED HELP!!Re: Brian Vigna Brian Vigna 01/13/01 04:55PM
