Re: M10 x 1mm pitch flanged nut- nut width = 15mm socket/spanner
Thomas TPRF /
Grind the hell out of your socket?
Use one of these?
https://www.amazon.com/dp/B01NCJH7TG/
Replace the nut with one of these and a washer?
https://www.amazon.com/dp/B07NQD3DQK/
Although stainless may be a bad choice. Generally with flywheels and pulleys and such you want a nut that is softer than the crank. Easier to replace a stripped nut than a stripped crank.
