Re: trying to go 45mph on av7 Moby. Possible?? help!!
Stephen Keller /
You should be able to see 40 without any of that stuff, READ the wiki, it is all laid out there. This is not a 4 cycle scooter engine where you can just plug and play, that pipe is for a much bigger carb and larger displacement cyl. The stock Motobecane pipe is actually very good, especially if opened up a bit, get the 15 carb and intake from treats, call it a day.
