is this true 42mph
this guy said everything is stock but is it true? I was curios because I have the same bike, av7, with no mods and I want to get the doppler? If just need to add those three mods he did. Help!!!
Re: is this true 42mph
How can everything be stock and have 3 mods ?
It's stock or it isn't .
sounds like a ported stock cylinder paired with a beefy aftermarket pipe. if you know how to port cylinders you could get the pipe and probably get good results?
Don't run lean...…..a little rich is best.
Bruce Zapper /
How did he start it?
Chöschi21 C.K. /
"Stock"... I wouldn't consider a Moped with a Ported Cylinder, Pipe and Filter "Stock"
kevin Smellaflange /
he could have used a 3/8'' drive adapter on his drill & started it that way.
or just push it or pedal.
(i know his center stand is wAaaaay bent).
There's literally a zip tie holding that pipe on.
You don't need that pipe to go 40 on a motobecane.
the moped Wiki has excellent port maps for av7 cylinders, then a SHA 15.15 and intake.. and a 2 roller ramp for the variator. any other mods for av7 is a waste, just get a av10 if you wanna go fast.
I think the guy even said it did 40 without the pipe...
> way.
No pedal chain on that bike...
probably has a smaller gear out the engine. thats how i got my moped to 40
