Well, the weather is getting nice.
Here is the flywheel off of a Variant on a 505 large tapered stock crank in 504 1/A cases. Used the same stator from the original 1980 Sparta Motoplat ignition. Coils sit about 0.58mm away from the ID of the flywheel. Cam seems to work the points perfectly. Kewl.
