E50 no power
I put a E50 together using a 70cc kit for a A35 I had lying around. It idles fine but does not accelerate at all just bogs. Has a mikuni vm20 first jet was a 120 dropped down to a 90 no change dropped to a 60 no change. I moved timing around and still no change. Any help would be appreciated.
Re: E50 no power
does it rev on the stand? do reeds look ok?
Targa seat/tank on that korado frame is dope btw
Re: E50 no power
Dirty30 Dillon /
I am going to guess that you have an airleak, combined with poor compression
Re: E50 no power
Chöschi21 C.K. /
This remindes me of something stupid i did, changed the Jetting around a ton and didn't notice any change at all, put the Piston in the wrong way so that it spit out gas into the Exhaust.
Re: E50 no power
if 120 main to 60 main theres no diff. it might just maybe be a clogged atomizer, clean and run some filters.
Re: E50 no power
It revs awesome on the stand. I noticed it smokes quite a bit could a bad oil seal on the clutch side cause that?
Re: E50 no power
Thanks. I didn’t like the way it looked stock and had all the parts in the shed.
Re: E50 no power
Your Vm20 should have a ~145-175 jet in it. 90 is waaaayyy to small. If its acting unusually rich and leaving heavy/thick white smoke it needs an oil seal.
Re: E50 no power
Second upjet. Sounds like lean bog. My vm20 e50 has 170 for the cold season
Re: E50 no power
Checking timing then leave it!
Is the piston correctly installed?
Try a new spark plug
Flue delivery
Kill switch wire short
Carb dirty
Huge fucking air leak
Re: E50 no power
TOP GUN™ ANDY ⚔ (LSLB) ⚔ /
if it doesnt have any power have you tried plugging it in
