Re: Head temp gauge for under $10 bucks!?
Thomas TPRF /
> Rocco Taco Wrote:
> > Alan Jackson Wrote:
> > so graham, if I drilled a hole in the head 10mm away from spark plug
> > (exhaust side) and 5-7mm? short of going all the way through and
> putting
> > my sensor wire in there and jb welding it I can imagine it would be
> > much more accurate than soldered to a copper washer under the spark
> > plug?
> I thought about doing that also. Not a Big fan of the jb weld. I think
> if you drilled a hole just big enough the wire would stay. You could
> also tap a small m5 hole
You’d need to make sure you get a solid connection for heat to conduct though. Maybe solder your probe into a copper or aluminum bolt?
Or use this sort of stuff? https://www.omega.com/googlebase/product.html?pn=OB-101-1/2&gclid=EAIaIQobChMI46rvsM3c4AIVCIvICh31gwizEAQYAyABEgITk_D_BwE
For general curiosity I like the idea of a probe in the head and a second in the cylinder next to the exhaust port. That one would be a bit harder, maybe, to place.
  Head temp gauge for under $10 bucks!?Topic by: * * * * 02/11/19 05:55AM
  Re: Head temp gauge for under $10 bucks!?Re: kevin Smellaflange kevin Smellaflange 02/11/19 09:11AM
  Re: Head temp gauge for under $10 bucks!?Re: Thomas TPRF Thomas TPRF 02/11/19 09:46AM
  Re: Head temp gauge for under $10 bucks!?Re: kevin Smellaflange kevin Smellaflange 02/11/19 09:53AM
  Re: Head temp gauge for under $10 bucks!?Re: John Konstantine John Konstantine 02/11/19 10:35AM
  Re: Head temp gauge for under $10 bucks!?Re: P D P D 02/11/19 10:46AM
  Re: Head temp gauge for under $10 bucks!?Re: Born to be WillD Born to be WillD 02/11/19 11:23AM
  Re: Head temp gauge for under $10 bucks!?Re: Totally normal JBOT Totally normal JBOT 02/11/19 01:56PM
  Re: Head temp gauge for under $10 bucks!?Re: Shane Rickert Shane Rickert 02/11/19 06:54PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/11/19 09:03PM
  Re: Head temp gauge for under $10 bucks!?Re: Rica Rivera Rica Rivera 02/11/19 09:10PM
  Re: Head temp gauge for under $10 bucks!?Re: Thomas TPRF Thomas TPRF 02/11/19 10:53PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/12/19 02:11AM
  Re: Head temp gauge for under $10 bucks!?Re: Thomas TPRF Thomas TPRF 02/12/19 02:26AM
  Re: Head temp gauge for under $10 bucks!?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 02/12/19 05:41AM
  Re: Head temp gauge for under $10 bucks!?Re: Josiah Radebaugh Josiah Radebaugh 02/12/19 09:37AM
  Re: Head temp gauge for under $10 bucks!?Re: P D P D 02/12/19 10:12AM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/22/19 06:50PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/22/19 07:42PM
  Re: Head temp gauge for under $10 bucks!?Re: kevin Smellaflange kevin Smellaflange 02/22/19 08:03PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/22/19 08:32PM
  Re: Head temp gauge for under $10 bucks!?Re: Alan Jackson Alan Jackson 02/23/19 05:44PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/23/19 06:53PM
  Re: Head temp gauge for under $10 bucks!?Re: Alan Jackson Alan Jackson 02/26/19 01:23PM
  Re: Head temp gauge for under $10 bucks!?Re: Ryan Graeme Ryan Graeme 02/26/19 02:39PM
  Re: Head temp gauge for under $10 bucks!?Re: Graham Motzing Graham Motzing 02/26/19 03:14PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/27/19 01:40PM
  Re: Head temp gauge for under $10 bucks!?Re: Graham Motzing Graham Motzing 02/26/19 01:57PM
  Re: Head temp gauge for under $10 bucks!?Re: Alan Jackson Alan Jackson 02/27/19 12:52PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/27/19 01:45PM
  Re: Head temp gauge for under $10 bucks!?Re: Thomas TPRF Thomas TPRF 02/27/19 02:10PM
  Re: Head temp gauge for under $10 bucks!?Re: Dirty30 Dillon Dirty30 Dillon 02/27/19 04:30PM
  Re: Head temp gauge for under $10 bucks!?Re: P D P D 02/27/19 04:44PM
  Re: Head temp gauge for under $10 bucks!?Re: Dirty30 Dillon Dirty30 Dillon 02/27/19 04:49PM
  Re: Head temp gauge for under $10 bucks!?Re: P D P D 02/27/19 04:51PM
  Re: Head temp gauge for under $10 bucks!?Re: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:04PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/27/19 05:13PM
  Re: Head temp gauge for under $10 bucks!?Re: Dirty30 Dillon Dirty30 Dillon 02/27/19 05:19PM
  Re: Head temp gauge for under $10 bucks!?Re: Alan Jackson Alan Jackson 03/02/19 04:55AM
  Re: Head temp gauge for under $10 bucks!?Re: Alan Jackson Alan Jackson 03/02/19 05:03AM
  Re: Head temp gauge for under $10 bucks!?Re: Ryan Graeme Ryan Graeme 02/27/19 02:31PM
  Re: Head temp gauge for under $10 bucks!?Re: Probably Fred Probably Fred 02/27/19 04:10PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/27/19 04:13PM
  Re: Head temp gauge for under $10 bucks!?Re: * * * * 02/27/19 04:15PM
