Stripped sachs plastic oil plug? Pro tip
For those sachs dandy boiz, your oil fill plug is stuck like a pair of small legos and your giant screwdriver is making an uglier mess than the latest halftime show? Just jab a sharp knife straight in there and use that to turn the old piece of shit outta there and throw it away! plug it back up with something that truly sparks joy, floss, brush and be on your way.
Re: Stripped sachs plastic oil plug? Pro tip
You are, and always will be, a mad man
totally going to move your plug boot over next time i see you
Tri-ped Dave O.D.B. /
I have plenty of NOS plastic plugs if you need, or even the entire Sachs factory gasket set which cleverly includes the plug
kevin Smellaflange /
3-D print a new batch & sell them for $999.999.00
Born to be WillD /
I did 3D print one. fits OK, capped it with some epoxy so it wouldn't seep through, the 3D print's not fully dense. but yea, that's the easy option if you got a 3d printer. makes alotta those dumb hard to find parts easily replaceable.
