Re: My Garage, Maxi, Hercules 623 Luxe, Hercules 624 Sport, Supermaxi and more
♣Slew Foot♣ /
http://www.technik-ostfriese.com/technik-ostfriese/ztrb.php . no German...
Sorry I'm using a voice app I thought that oil drip was a bad seal but like I said if you look at the clutch diagrams in the blowouts there is a small washer that has holes all around it and it's cup-shaped some of them require it before the clutch Bell because if you have a two gang wear a three gang should be it makes up for the millimeter or two if you don't the clutch slaps back and forth a little and it knocks the seal
Chöschi21 C.K. /
Sorry for the Confusion, but that's a Puch E50 that you see on those pics.
♣Slew Foot♣ /
K. The shiming good on the clutch and bell wha happen?
Chöschi21 C.K. /
Shimming should be okay, i don't know how much play the cluch bell should have, it doesn't have much, if any. Cluch and all the other stuff didn't look bad, that damage on the Transmission seems to have been there before, but why so many Chips in the Oil?
♣Slew Foot♣ /
The starter plates are dragging. It shouldn't be engaged while the engine is running those aren't like chips on the gear or from the gear rather that's just like gray stuff in the tranny fluid like where it's s***
Chöschi21 C.K. /
I had enough play in the Starting lever, why should it be dragging, and why would that make a Rough sound, like crunching at certain Rpm's (somewhere between 8'500 and 10'000)
♣Slew Foot♣ /
Intermittent bearing seizure probably a needle bearing somewhere that Mark on your crank s*** it's probably inside the clutch Bell
Chöschi21 C.K. /
I found out why there were a lot of Chpis in the Oil and i found out why it made such bad sounds.
Sure , just keep it all to yourself . :(
Chöschi21 C.K. /
Anybody got a guess?
IDK , we just had a full moon . I suppose that had something to do wit it . ;)
Chöschi21 C.K. /
the ignition side bearing has about 0.5mm play inside the block and someone put a nail into the Transmission-vent, Secured it and that thing that he secured it with fell into the Transmission.
I knew the full moon had something to do with it . LOL
Chöschi21 C.K. /
I swa a Moped a couple of days ago, might get it, it's a Grey Supermaxi, pics Following.
Chöschi21 C.K. /
How and where did you get the bike. In your country or somewhere adjacent?
Chöschi21 C.K. /
Wich one?
That Grey Supermaxi isn't mine, don't know the Owner, if it's still there when my Engine is Finished i will ask about it and if i could have it.
