Re: Bing on a honda nu50
Chris . /
7/8 inch expansion plug from auto parts store works, but needs to be tightened every so often. treats sells the mlm aluminum one but the one review said it pops out, they should make a bracket to hold it in place that uses the oil pump bolt hole. another option is cut the pump shaft off where the gear rides the crank, but i like having the whole thing gone for easier carb removal.
