Re: Bing on a honda nu50
Captain Janeway /
> Mike Mills Wrote:
> Yeah. Running a 15 on mine . Forever lean at idle but i found other
> issues. Oil injection pump for instance. Seal falls off the shaft
> creating a case leak. Ditch it and plug the hole. Might run better. Head
> leak atm will report back.
> Setup:
> Mlm pipe
> Kstar 60 kit
> Boysen dual stage reeds
> New crankshaft seals
> 15bing clone w/2.22 atomizer and 85 main needle in the middle
> Home made bing flange adapter (bar stock bored with a 9/16 socket
> pressed in and tigged)
Like the intake. what did you use as an air box on this one?
Had an intake put together for an SHA that faced back like this one. It was so tight all that could fit was the SHA airbox which is so loud it leaves you with ringing ears.
