Re: Sachs G3 505/1D VM20 fit
Born to be WillD /
> P D Wrote:
> > Born to be WillD Wrote:
> > personally if I were cutting and welding, I'd rather cut and weld the
> > downtube bar. they come off quite easily and you could just put a
> little
> > bend or bump there to clear the intake. Any welds in the intake, even
> > done very cleanly are gonna create turbulence, and any cut/bends in
> the
> > intake are gonna take some of the smooth transitions out.
> So , you'd rather weaken an already questionable frame than create a bit
> of beneficial turbulence in the intake ?
I appreaciate your opinion, while recognizing you're not well experienced with the sachs g3.
those down bars are near entirely useless, theyre almost exclusively an aesthetic choice and only support the front motor mount. They have no impact on the frame, and people regularly remove them entirely when running alternate swapped motors. So yea, I totally would cut out a piece of that frame.
Also you can find those pieces cheaper than the intakes
