Re: Bye Bike in USA
Charlie BUZZARD /
You could go with stronger clutch springs. That would let the motor rev closer to the power band and increase your take off. It shouldn't be necessary. It sounds like something is wrong with your bike though. I've ridden stock single speeds that get up and go better than that.
If you have the tools, do some reading on basic variator and clutch tuning.
Crash course is, the weights react to the centrifugal force of the spinning variator. When the motor spins, this makes them sling outwards thus forcing the variator cheek to move over and causing the variator to force the belt out from the center. Think of it like gears on a 10 speed bike. When the belt sits allnthe way down into the variatorz that is like 1st gear. When the belt is riding all. The way out towards the outer egde of the variator pulley cheeks, this is like 10th gear. Now the lighter the variator rollers are. The faster the motor will have to spin before it starts to "shift gears". The heavier the weights are, the variator with shift into a taller gearing sooner.
If you are experiencing slower take off listen to the motor. Is it screaming or does it soundnlike its reving very high but the bike isn't accelerating? This may mean that your weights are to light to respond to centrifugal force from the motor. You would need to increase the roller weight incrementally untill you are satisfied with the take off. Too light of a roller will mean your bike will never fully shift into its top speed.
Is your bike just bogging off the line not reving high enough to make any power? This may men your roller weights are to heavy. They are being slung outward to quickly and causeing the bike to shift before it can make any power. You will have to lighten the roller weights. But do it incrementally. You dont want to go too light, because your bike will not fully shift gears.
Think the clutch the exact same way. The clutch spins with the motor. As it spins centrifugal force will cause the hinged clutch "shoes" to swing outward and eventually come in contact with and force the clutch bell to spin with it. Which is what turns the front sprocket and spins you lr back wheel. The shoe is helded in it's closed position with a tight spring. When the bike revs up the centrifugal force caused the shoe to stretch the spring and swing outward. These clutch springs come in different strengths. The weaker ones, or also referred to as "light springs" will take less centrifugal force to stretch the spring. Meaning it will engage with the bell at a lower RPM. If the clutch engages to soon, the bike will not have reached its power band. This is the region of a bikes RPM range where the bike makes peak power. If it does not reve very high before moving and feels boggy and unresponsive, you may need tighternor "heavier springs". Adversely, if the bike revs very high and never really starts to pull hard. This could mean that the motor can not create enough centrifugal force to overcome the clutch springs. Thus the clutch shoes never fully engage with the bell. You may need weaker or lighter springs.
That's the long and short of it. It's not to hard to find a balance you will like if you have the tools, the time to wrench, and some basic mechanical skills.
There is slew of basic things that could be goingnwrong and robbing you of power. Other things could be an air leak making bike to lean, the timing being off, clogged airfilter or even a clogged exhaust. I've seen crazy stuff clog exhausts and baffle (no pun intended) people wrenching on the bike.
I hope that helps! Don't be afraid to as Second Stoke to help you out. They can ride it and will be able to tell if it should be performing better, and will likely know how to help you out.
  Bye Bike in USATopic by: Blake MD No PM Plz Blake MD No PM Plz 01/21/19 04:04PM
  Re: Bye Bike in USARe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/21/19 04:07PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/21/19 04:10PM
  Re: Bye Bike in USARe: Chöschi21 C.K. Chöschi21 C.K. 01/21/19 04:08PM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 01/22/19 04:04AM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 01/22/19 01:56PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/22/19 04:05PM
  Re: Bye Bike in USARe: Dave Steele Dave Steele 01/22/19 04:19PM
  Re: Bye Bike in USARe: TOP GUN™ ANDY ⚔ (LSLB) ⚔ TOP GUN™ ANDY ⚔ (LSLB) ⚔ 01/22/19 04:27PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/08/19 06:27PM
  Re: Bye Bike in USARe: Bas Autowas Bas Autowas 01/21/19 04:16PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/21/19 04:30PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/08/19 01:01AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/14/19 11:02PM
  Re: Bye Bike in USARe: Max LGN Max LGN 01/21/19 04:23PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/21/19 04:32PM
  Re: Bye Bike in USARe: Max LGN Max LGN 01/22/19 09:48AM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 01/21/19 04:41PM
  Re: Bye Bike in USARe: Les B. Les B. 01/21/19 04:24PM
  Re: Bye Bike in USARe: Jesse Gomez Jesse Gomez 01/21/19 04:49PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/08/19 06:20PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/08/19 07:09PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/11/19 06:11PM
  Re: Bye Bike in USARe: Graham Motzing Graham Motzing 01/21/19 05:27PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/21/19 08:05PM
  Re: Bye Bike in USARe: jonny 5ive jonny 5ive 01/21/19 08:35PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/21/19 09:56PM
  Re: Bye Bike in USARe: Dmitry K. Dmitry K. 01/21/19 09:13PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/21/19 10:00PM
  Re: Bye Bike in USARe: Rica Rivera Rica Rivera 01/21/19 09:41PM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 01/22/19 08:22AM
  Re: Bye Bike in USARe: Jerrod Mindykowski Jerrod Mindykowski 01/22/19 09:14AM
  Re: Bye Bike in USARe: MPB Andyrew MPB Andyrew 01/22/19 09:53AM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/22/19 02:36PM
  Re: Bye Bike in USARe: Dave & Bummerzz Dave & Bummerzz 01/22/19 04:48PM
  Re: Bye Bike in USARe: Toledo Riot Toledo Riot 01/22/19 04:13PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/22/19 04:15PM
  Re: Bye Bike in USARe: Toledo Riot Toledo Riot 01/22/19 04:19PM
  Re: Bye Bike in USARe: Ryan N. Ryan N. 01/22/19 04:25PM
  Re: Bye Bike in USARe: Tim R Tim R 01/22/19 05:19PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/22/19 08:55PM
  Re: Bye Bike in USARe: kevin Smellaflange kevin Smellaflange 01/22/19 06:27PM
  Re: Bye Bike in USARe: Chris Squid Chris Squid 01/22/19 06:27PM
  Re: Bye Bike in USARe: Zach Riddle Zach Riddle 01/22/19 06:56PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/22/19 08:53PM
  Re: Bye Bike in USARe: Bas Autowas Bas Autowas 01/23/19 04:43AM
  Re: Bye Bike in USARe: Wild Card Wild Card 01/23/19 04:55AM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/23/19 11:26AM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/23/19 11:24AM
  Re: Bye Bike in USARe: P D P D 01/23/19 11:30AM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/23/19 12:49PM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 01/23/19 11:34AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 01/23/19 01:39PM
  Re: Bye Bike in USARe: Josiah Radebaugh Josiah Radebaugh 01/23/19 01:42PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/23/19 02:07PM
  Re: Bye Bike in USARe: Josiah Radebaugh Josiah Radebaugh 01/23/19 04:13PM
  Re: Bye Bike in USARe: Richard Schwartz Richard Schwartz 01/22/19 09:13PM
  Re: Bye Bike in USARe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/22/19 09:37PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/22/19 10:25PM
  Re: Bye Bike in USARe: Alexandro Ramirez-Nagy Alexandro Ramirez-Nagy 01/23/19 12:53PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 01/23/19 12:56PM
  Re: Bye Bike in USARe: Josiah Radebaugh Josiah Radebaugh 01/23/19 01:38PM
  Re: Bye Bike in USARe: Chöschi21 C.K. Chöschi21 C.K. 01/24/19 01:22AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/08/19 01:23AM
  Re: Bye Bike in USARe: Dave & Bummerzz Dave & Bummerzz 09/08/19 08:34AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/11/19 06:08PM
  Re: Bye Bike in USARe: Josiah Radebaugh Josiah Radebaugh 09/12/19 10:06AM
  Re: Bye Bike in USARe: Rica Rivera Rica Rivera 09/08/19 05:19PM
  Re: Bye Bike in USARe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/23/19 06:31AM
  Re: Bye Bike in USARe: derek from black pipes moped gang 🌧 derek from black pipes moped gang 🌧 01/23/19 07:38AM
  Re: Bye Bike in USARe: Phoebe Sux Phoebe Sux 01/23/19 10:19AM
  Re: Bye Bike in USARe: Max LGN Max LGN 01/23/19 12:52PM
  Re: Bye Bike in USARe: Cory KCMO Cory KCMO 01/23/19 01:19PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/23/19 01:28PM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 01/23/19 01:35PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/23/19 01:37PM
  Re: Bye Bike in USARe: Max LGN Max LGN 01/23/19 01:20PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/23/19 03:24PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/23/19 04:05PM
  Re: Bye Bike in USARe: P8R . P8R . 01/23/19 06:07PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/23/19 09:50PM
  Re: Bye Bike in USARe: MPB Andyrew MPB Andyrew 01/23/19 02:05PM
  Re: Bye Bike in USARe: Max LGN Max LGN 01/23/19 03:44PM
  Re: Bye Bike in USARe: Don Ohio Don Ohio 01/23/19 04:23PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/23/19 04:44PM
  Re: Bye Bike in USARe: Charles Cole (OFMC) Charles Cole (OFMC) 01/23/19 08:34PM
  Re: Bye Bike in USARe: «tyler » «tyler » 01/23/19 09:45PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/23/19 09:52PM
  Re: Bye Bike in USARe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/23/19 11:30PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 01/23/19 11:56PM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 01/24/19 03:21AM
  Re: Bye Bike in USARe: Stephen Keller Stephen Keller 01/24/19 03:50AM
  Re: Bye Bike in USARe: Wild Card Wild Card 01/24/19 05:06AM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 01/29/19 03:47AM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 01/29/19 04:45PM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 01/29/19 04:52PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 01/29/19 05:14PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/29/19 05:09PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 01/29/19 06:03PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/29/19 06:25PM
  Re: Bye Bike in USARe: no groms no blasters no groms no blasters 01/29/19 08:08PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/29/19 08:25PM
  Re: Bye Bike in USARe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/29/19 08:45PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 01/29/19 09:00PM
  Re: Bye Bike in USARe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 01/31/19 09:33AM
  Re: Bye Bike in USARe: Ryan Graeme Ryan Graeme 01/30/19 01:23AM
  Re: Bye Bike in USARe: Derek Stahl Derek Stahl 01/30/19 02:50AM
  Re: Bye Bike in USARe: Ryan N. Ryan N. 01/30/19 09:17AM
  Re: Bye Bike in USARe: Dead Possum Dead Possum 01/30/19 02:25PM
  Re: Bye Bike in USARe: Lou MAGNETO Lou MAGNETO 02/07/19 12:29AM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 02/07/19 07:30AM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 02/07/19 10:04AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/15/19 01:45AM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/15/19 02:10AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/15/19 08:11PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/15/19 08:07PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/15/19 09:23PM
  Re: Bye Bike in USARe: Ryan Graeme Ryan Graeme 09/15/19 11:44PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/18/19 08:33PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/25/19 04:18AM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/25/19 09:29AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/28/19 01:21PM
  Re: Bye Bike in USARe: davide valli davide valli 04/11/21 06:08AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 02/07/19 09:19AM
  Re: Bye Bike in USARe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 02/07/19 09:22AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 02/11/19 11:15AM
  Re: Bye Bike in USARe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 02/11/19 05:03PM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 02/14/19 07:02AM
  Re: Bye Bike in USARe: LSLB Lou 😤 LSLB Lou 😤 02/13/19 11:58AM
  Re: Bye Bike in USARe: Jerrod Mindykowski Jerrod Mindykowski 02/13/19 12:15PM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 02/07/19 06:04PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 02/07/19 06:44PM
  Re: Bye Bike in USARe: Benjamin The Wandering Pacer Benjamin The Wandering Pacer 02/08/19 02:14PM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 02/08/19 02:31PM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 02/14/19 07:40AM
  Re: Bye Bike in USARe: Bas Autowas Bas Autowas 02/14/19 07:50AM
  Re: Bye Bike in USARe: Lazy Pedaler Lazy Pedaler 02/14/19 08:17AM
  Re: Bye Bike in USARe: Lazy Pedaler Lazy Pedaler 03/03/19 11:08AM
  Re: Bye Bike in USARe: johan wallarbro johan wallarbro 03/24/19 02:48PM
  Re: Bye Bike in USARe: Ryan Graeme Ryan Graeme 03/24/19 03:17PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/08/19 09:22AM
  Re: Bye Bike in USARe: live ɘvil live ɘvil 09/08/19 10:37AM
  Re: Bye Bike in USARe: Dave & Bummerzz Dave & Bummerzz 09/08/19 05:33PM
  Re: Bye Bike in USARe: Graham Motzing Graham Motzing 09/11/19 06:11PM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 09/12/19 09:58AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/14/19 10:31PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/14/19 11:02PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/15/19 01:12AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/15/19 08:22PM
  Re: Bye Bike in USARe: P D P D 09/15/19 08:49PM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 09/18/19 11:34PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 09/18/19 11:39PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/19/19 12:06PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/19/19 12:13PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/20/19 10:58AM
  Re: Bye Bike in USARe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 09/20/19 11:05AM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 09/20/19 11:19AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 09/23/19 01:18PM
  Re: Bye Bike in USARe: Josiah Radebaugh Josiah Radebaugh 09/23/19 01:34PM
  Re: Bye Bike in USARe: Dave Steele Dave Steele 09/23/19 02:55PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/23/19 03:12PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/23/19 10:12PM
  Re: Bye Bike in USARe: Marc Friedman Marc Friedman 09/19/19 11:18AM
  Re: Bye Bike in USARe: campeona del mundo campeona del mundo 09/19/19 12:49PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/19/19 07:40PM
  Re: Bye Bike in USARe: Bas Autowas Bas Autowas 09/20/19 12:04PM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 09/20/19 12:12PM
  Re: Bye Bike in USARe: Bas Autowas Bas Autowas 09/20/19 12:20PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/20/19 12:26PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/21/19 10:18AM
  Re: Bye Bike in USARe: Dave & Bummerzz Dave & Bummerzz 09/21/19 12:25PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/21/19 01:27PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/22/19 09:32PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/23/19 01:13AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/23/19 10:14AM
  Re: Bye Bike in USARe: Bas Autowas Bas Autowas 09/23/19 10:43AM
  Re: Bye Bike in USARe: Fred Braue Fred Braue 09/20/19 04:13PM
  Re: Bye Bike in USARe: Upjet Cause Upjet Cause 09/21/19 11:01AM
  Re: Bye Bike in USARe: Dan (high idle) Conway Dan (high idle) Conway 10/09/19 12:21AM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 10/09/19 09:08PM
  Re: Bye Bike in USARe: Toledo Riot Toledo Riot 12/10/19 09:35AM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 12/10/19 09:40AM
  Re: Bye Bike in USARe: Downhill Harvey (OFMC) Downhill Harvey (OFMC) 12/24/19 06:48PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 12/24/19 06:54PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 02/23/20 07:49PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 02/23/20 07:54PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 02/23/20 09:09PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 02/23/20 08:10PM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 09/21/19 11:20AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/22/19 08:58PM
  Re: Bye Bike in USARe: P D P D 09/22/19 09:02PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/22/19 09:13PM
  Re: Bye Bike in USARe: P D P D 09/22/19 09:17PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/22/19 09:09PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/22/19 09:18PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/23/19 12:44AM
  Re: Bye Bike in USARe: Dirty30 Dillon Dirty30 Dillon 09/23/19 09:14AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/25/19 04:14AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/28/19 10:40AM
  Re: Bye Bike in USARe: Dave & Bummerzz Dave & Bummerzz 09/30/19 09:36AM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 10/01/19 01:34AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 10/01/19 06:40AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 10/04/19 04:37PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 10/04/19 10:49PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 10/04/19 11:41PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 10/05/19 12:29AM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 10/05/19 01:27AM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 10/05/19 04:06AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 10/05/19 11:35AM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 10/05/19 12:06PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 10/05/19 12:16PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 10/07/19 09:49PM
  Re: Bye Bike in USARe: jayson sumpter jayson sumpter 10/08/19 10:32AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/23/19 10:05AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 09/23/19 03:18PM
  Re: Bye Bike in USARe: EH FCC of the QCB EH FCC of the QCB 09/23/19 05:28PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/23/19 11:26PM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 09/24/19 01:12PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/24/19 03:00PM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 09/24/19 11:35PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/28/19 10:45AM
  Re: Bye Bike in USARe: Tony montana Tony montana 09/30/19 08:01AM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/30/19 08:42AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/30/19 09:29PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/30/19 09:32PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/30/19 09:37PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 09/30/19 09:51PM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 09/30/19 09:57PM
  Re: Bye Bike in USARe: Charlie BUZZARD Charlie BUZZARD 09/30/19 09:02AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 10/04/19 04:38PM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 10/05/19 01:15AM
  Re: Bye Bike in USARe: Dan O Dan O 10/06/19 07:07PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 10/08/19 11:03AM
  Re: Bye Bike in USARe: johan wallarbro johan wallarbro 10/08/19 03:13PM
  Re: Bye Bike in USARe: johan wallarbro johan wallarbro 10/09/19 05:42PM
  Re: Bye Bike in USARe: johan wallarbro johan wallarbro 12/08/19 11:08AM
  Re: Bye Bike in USARe: no groms no blasters no groms no blasters 02/23/20 08:27PM
  Re: Bye Bike in USARe: Brandon Love Brandon Love 02/24/20 07:15AM
  Re: Bye Bike in USARe: Daniel '' Daniel '' 02/24/20 12:00PM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 02/24/20 12:07PM
  Re: Bye Bike in USARe: campeona del mundo campeona del mundo 02/24/20 05:18PM
  Re: Bye Bike in USARe: Jackerz ! Jackerz ! 02/24/20 10:42PM
  Re: Bye Bike in USARe: Garrett The Kid Garrett The Kid 02/25/20 01:46AM
  Re: Bye Bike in USARe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 02/25/20 10:43AM
  Re: Bye Bike in USARe: Darren Jackson Darren Jackson 03/01/20 04:41PM
  Re: Bye Bike in USARe: Aaron Blair Aaron Blair 02/25/20 09:25AM
  Re: Bye Bike in USA with Shinko Sr21 dual sport tiresRe: Darren Jackson Darren Jackson 02/29/20 11:28PM
  Re: Bye Bike in USARe: classic carl jepsen classic carl jepsen 05/01/20 05:51PM
  Re: Bye Bike in USARe: tom wizard tom wizard 06/21/20 09:52PM
  Re: Bye Bike in USARe: Thomas TPRF Thomas TPRF 06/21/20 11:02PM
  Re: Bye Bike in USARe: Gator San Juan Gator San Juan 06/22/20 03:25PM
  Re: Bye Bike in USARe: no groms no blasters no groms no blasters 06/22/20 03:50PM
  Re: Bye Bike in USARe: Marc Friedman Marc Friedman 06/22/20 04:02PM
  Re: Bye Bike in USARe: b to the eff b to the eff 06/29/21 02:17AM
  Re: Bye Bike in USARe: Terbo Speghetti Terbo Speghetti 06/29/21 07:19AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 06/29/21 09:11AM
  Re: Bye Bike in USARe: EH FCC of the QCB EH FCC of the QCB 06/29/21 04:21PM
  Re: Bye Bike in USARe: Terbo Speghetti Terbo Speghetti 09/29/20 09:36PM
  Re: Bye Bike in USARe: b to the eff b to the eff 06/29/21 04:22PM
  Re: Bye Bike in USARe: Max Ginsburg Max Ginsburg 06/30/21 08:51AM
  Re: Bye Bike in USARe: Marc Friedman Marc Friedman 06/30/21 10:42AM
  Re: Bye Bike in USARe: Born to be WillD Born to be WillD 06/30/21 04:50PM
  Re: Bye Bike in USARe: Marc Friedman Marc Friedman 06/30/21 06:59PM
  Re: Bye Bike in USARe: no groms no blasters no groms no blasters 06/30/21 03:29PM
  Re: Bye Bike in USARe: Jonathan R Jonathan R 06/30/21 03:56PM
  Re: Bye Bike in USARe: D L D L 08/13/21 04:28PM
  Re: Bye Bike in USARe: b to the eff b to the eff 08/13/21 05:50PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 08/13/21 08:09PM
  Re: Bye Bike in USARe: Blake MD No PM Plz Blake MD No PM Plz 08/13/21 08:16PM
  Re: Bye Bike in USARe: D L D L 08/13/21 08:27PM
  Re: Bye Bike in USARe: Toledo Riot Toledo Riot 08/13/21 11:00PM
  Re: Bye Bike in USARe: b to the eff b to the eff 08/13/21 09:27PM
  Re: Bye Bike in USARe: Gator San Juan Gator San Juan 08/14/21 04:10PM
