Re: Bye Bike in USA
Josiah Radebaugh /
Depends what state
Re: Bye Bike in USA
> Thomas TPRF Wrote:
> > Don Ohio Wrote:
> > Now's the time to get opinions from us buyers. I'd like to see a wider
> > and cushier seat if possible, and mirrors that look more classic.
> > Just dreamin of a StreetMate -like ped,guys.
> Sneak pic of US spec version.
Mopedarmy needs more of this. thank you for all you do
Re: Bye Bike in USA
Josiah Radebaugh /
I don't quite like how scootery they look but I'd consider buying one after a ride.
Re: Bye Bike in USA
Re: Bye Bike in USA
> after a ride.
If I buy one Ima gonna do some trimming. The SNAIL look will be gone when I'm done.
Re: Bye Bike in USA
> Max LGN Wrote:
> That looks like a nice factory. Fanuc Robodrill 5 axis mills, CMM for
> inspection,
> robotic welding. Ugh dream job is be the guy holding bikes WOT on a dyno
> haha
> Are the really using plastic on the kickstart plate though?
If we’re looking at the same thing looks like a 139qmb style variator assembly. Only plastic bit is the fan. The kickstart works off the center spider washer, the teeth on the edge of the pulley are for the electric starter.
Re: Bye Bike in USA
Ah ok, i thought the center piece the fan attaches too looked plastic.
Re: Bye Bike in USA
Blake MD No PM Plz /
What he said is correct. Just the fan is plastic. The kicker assembly is all metal. A little awkward on the forward kick but you should only have to use it if the battery dies. Also, the 110mm drum brakes work very well but a disc option is something we discussed in person when we met with Rieju at EICMA.
For those curious, the seat is 9 1/2" wide and 21" long on the One Plus models. I should call Corbin and see if they want to make one ha. Its a pretty large bike for a moped.
Re: Bye Bike in USA
Josiah Radebaugh /
Ahhh yes.
Re: Bye Bike in USA
Quote: `For those curious, the seat is 9 1/2" wide and 21" long on the One Plus models. I should call Corbin and see if they want to make one ha. Its a pretty large bike for a moped.'
Just needs to be a thicker seat if possible. Not a deal-breaker. Plenty wide at 9.5".
Re: Bye Bike in USA
Among people that like to name their bikes what do you think will be the most common?
Lemme borrow yo moped real quick
Re: Bye Bike in USA
Bikes look pretty fun, but hate the name. Hopefully the epa will make you rebrand them as dos hoggos
Re: Bye Bike in USA
Charles Cole (OFMC) /
Silvia, Named after one of my beautiful Black Australorps. Broke my heart when she died. (edited)
Re: Bye Bike in USA
This is the weirdest thread in a minute.
Really cool bikes though. I can't wait to buy a broken one from a dingus.
Re: Bye Bike in USA
Re: Bye Bike in USA
> dingus.
I’m with you on that. I want way more cool stuff being sold so I can buy it for $100 next year from some SCAD kid that’s moving and doesn’t know how to clean a carb.
Re: Bye Bike in USA
🇮🇹💦 Of the Loin /
drum brakes are really nice on small bikes
dont want antsy pantsy going over the handlebars
Re: Bye Bike in USA
Bye Felicia
Re: Bye Bike in USA
Chöschi21 C.K. /
In Europe these are avalable as 30 and 20mph Trims stock.
Re: Bye Bike in USA
At least there are 3 variants for Europe: 25 and 45 km/h and 30 km/h with pedals for Switzerland.
Re: Bye Bike in USA
Looks good, forks look spindly? I know it was addressed in an earlier post, must just be the picture angles? Everything else looks great! Would love to see one in person.
Re: Bye Bike in USA
These rip. We rode mopeds to the Buzzards rally from ATL and this thing led the pack the whole 250 miles.
Re: Bye Bike in USA
Re: Bye Bike in USA
Technigas also makes a pretty solid looking exhaust. Ive heard that you cant delete the oil injection on these, if you do they seize the crank bearings.
Re: Bye Bike in USA
Dirty30 Dillon /
> bearings.
Like 70's/80's Suzuki's, I'm sure that can be remedied by removing the oil slingers. The case Design is incredibly similar to the StartV cases, so I can't see it being drastically altered to disable removing the OI
Re: Bye Bike in USA
Oil is injected through the carburetor body. I don't see any reason it couldn't be safely removed.
> bearings.
Re: Bye Bike in USA
Just what I heard, Rodney had a bye bike engine on one if his builds and ran it without the oil injection. It seized the crank bearing in <100 miles, I was wondering how that could be possible as I was assuming the oil was fed through the carb.
Re: Bye Bike in USA
Some scooter oil pumps, TGB for one, have the oil feed running both to the carb and to dripper nozzles on the intake just above the crank bearing feed holes.... Are they set up like that?
Re: Bye Bike in USA
Nope. Oil is only injected through the carburetor body. Behind the ignition is a gear driving a pump. Remove a snap ring and the gear slides off. Everything else can be left in place if you like or removed with 2 bolts.
Re: Bye Bike in USA
no groms no blasters /
HEY DOS CYCLES:
Is Reiju investing the money in homologation, or is Dos Cycles? Did Reiju decide to try to break into the American market, or did Dos Cycles approach them to get their product into America?
What's the story?
I look forward to buying one, taking it completely apart, and powdercoating it multi-dayglo as Internette pt 2.
