Making a list, getting the wallet out
ben henderson /
The tomos is running well with the tank cleaned and a proper filter in place.
Today I went through the other issues.
Rear swing arm bushings are toast, 3/4'' of play on the rear wheel
Chain is stretched out
flywheel cover is broken where the kickstart return spring goes
Flywheel cover is also missing the oil injection cover.
both tires have dry rot, cracks. They hold air, but not sure I trust them going
36mph not to bust.
The rear exhaust mount is broke from the frame. needs welding.
The kickstand goes past where it should to hold up the bike, looks like part of
the kickstand frame is broke. Hopefully can weld it back into place.
Throttle cable works but is sketchy...electrical tape holding it into the twist grip.
Rear shocks were never meant to hold 260 pounds of manliness and are old to
boot, bottoms out on some bumps.
Easily looking at spending $250-$300...plus painting it in order for it to be a nice
moped. I have $150 in it now. Hopefully there will be some tax money left over
to use on the bike!
